Jacking Question
Old Jun 14, 2007 | 12:24 AM
POK868's Avatar
POK868
Default Jacking Question
Am I going to hurt anything by Jacking up using the frame and pucks, I was planning on jacking up one corner at a time swapping the wheel, then moving on to the next corner. Any advice not to eff up my car.
Bought some Z06 Rims and want to swap out for the thin spokes that are on there.
Thanks,
Jon
Old Jun 14, 2007 | 01:19 AM
RoccoC5's Avatar
RoccoC5
You'll have no problems if you use the pucks. I've had my car up a few times with a jack for brakes, sway bar, etc and have had no issues. Soon I'll have a lift in my garage and my work will be a helluva lot easier!
Old Jun 14, 2007 | 04:18 AM
Third Gear's Avatar
Third Gear
It won't hurt anything... you might hear a few noises - don't worry. Oh btw a Kwik Lift is worth every cent.
Oh - most importantly make absolutely sure to always use jack stands once you get it up in the air. You never know when a jack will bleed or fail... I think my somewhat new racing jack is on its way out - left a nice little puddle of grease... thank you jack stands or else my car would be toast.
Old Jun 14, 2007 | 08:33 AM
Ranger's Avatar
Ranger
Thanks,
Jon
Hi POK868.
Here is the jack-point diagram from a C5 service manual. Official info to supplement....see thumbnail
To lift both rear wheels at the same time, I put a 2"x6" on the jack and lift at the rear cross-member, as shown in the diagram.
Ranger
Old Jun 14, 2007 | 04:59 PM
dndrsn's Avatar
dndrsn
Old Jun 14, 2007 | 05:20 PM
BanditDude's Avatar
BanditDude
Originally Posted by Ranger
Hi POK868.
Ranger
I do the same with the front. However, I have to drive up on ramps to get the jack underneath.
Old Jun 14, 2007 | 07:16 PM
T VETTE's Avatar
T VETTE
That is how I do it, one corner at a time with a puck.
Old Jun 14, 2007 | 08:15 PM
alini's Avatar
alini
So I guess I need to go get a set of pucks huh
Old Jun 14, 2007 | 08:28 PM
Patches's Avatar
Patches
Originally Posted by dndrsn
One of my favorite vids. Don't know why . . .
Old Jun 14, 2007 | 10:52 PM
Bill Dearborn's Avatar
Bill Dearborn
I use the lift points on the frame for jacking the car. If you just lift one corner at a time the frame will stand the weight. Since I do a lot of tire changing between DOT R tires and street tires I usually just jack at the front lift point and lift both wheels (NASCAR style) off the ground at one time. It saves a lot of hassle but the frame is then holding about half the weight of the car in the little circle of the jacking puck and after jacking the car 20 or 30 times will tend to dent inwards at that point. If you use a 6 inch piece of 2 x 4 instead of the puck the frame will be fine.
Bill
Old Jun 15, 2007 | 11:54 AM
Ron222's Avatar
Ron222
DNDRSN,
Was a little worried about jacking up my vette for the first time as well, read about doing it but never actually say anyone do it. Your video put me at ease. Thanks
Old Jun 16, 2007 | 12:30 PM
dndrsn's Avatar
dndrsn
Here's another for your enjoyment.
The Handy Dandy Self-Centering Jacking Board.
Old Jun 16, 2007 | 02:04 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
Default Jacking up the C5
I have seen people at SCCA events with a C6 jack from the side and lift both wheels off the ground on one side at a time. It is a quick way to do a switch but is this safe with a C5?
To Jacking Question
