Spark Plug Boot Removal
Old Jun 14, 2007 | 10:46 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Spark Plug Boot Removal
Tried changing the plugs but I couldn't free up the plug wire boots. I tried twisting/pulling but they will not come off the plugs. Anybody have any suggestions on how to remove?
Bill
Old Jun 14, 2007 | 10:50 PM
Racer1x's Avatar
Racer1x
I just replaced mine and pryed them off with a screwdriver, there is a groove towards the top.
Old Jun 14, 2007 | 11:00 PM
rcs128's Avatar
rcs128
When I did mine I replaced the wires, too, so I just grabbed the ends of the boots (the rubber part, not the metal part) with a pair of pliers and pulled them straight off. The heavy-handed approach didn't seem to do any damage, but like I said, I didn't re-use the wires.
It seem like at first they don't want to give, but once you give them just enough pull they pop right off.
Old Jun 15, 2007 | 07:53 AM
ryoder's Avatar
ryoder
PLEASE WEAR GLOVES!
My computer programmer's hands are not as tough as they were back in the day. When I twisted the boots off I put a lot of muscle in it and didn't realize till halfway through the project that my thumb and index fingers on both hands were bubbled up. I had to quit working on it and it was embarrassing at work.
Also go buy new plug wires before you go ripping them off because if you need to get aggressive it wont matter so much if you break one or two. I did and had to drive .5 miles on 7 cylinders to Advance to get some wires.
I just drove to Advance on a flat last weekend too!
Old Jun 15, 2007 | 10:13 AM
Dope's Avatar
Dope
Resident moron
Pull harder! Either it'll break or it'll come off, that's about all you can do
When putting them back on, put some dieletric grease on the connections to make it easy next time.
Dope
Old Jun 15, 2007 | 04:02 PM
craig04c5's Avatar
craig04c5
Yep, hardest part of the job is getting those %^*(^%ing boots off. I also just used pliers and pulled the ones I could not twist off. I did not ruin any but then again I took my plugs out at 12K miles and put anti-seize on the plug threads and dielectric grease in the boots so I would not have trouble a couple years from now when they need changing.
To Spark Plug Boot Removal
