Pigtail Help Please
Old Jun 15, 2007 | 05:47 PM
jost6453's Avatar
jost6453
Default Pigtail Help Please
The oil pressure sender on my '02 crapped out last night. I've been reading the sticky and all the posts on fix options and thought that if I could unhook my sender without cutting an access hole ... or without removing the intake ... I'd relocated the sender to the front of the block. Well .... I was able to get down in there with a stiff wire and pop the connector off quite easily. Thougth I was home free! Wrong. The harness end is too short to give me enough room to splice into the wires. I can barely get it up high enough to maybe plug a pigtail into it if I could find the connector ends to make an extender. Does anyone know where I could get both a male and female connectors so I can make an extension and just plug the extension into the existing harness?
