The rotor should be positioned based upon the vanes in the rotor and not the slots on the face of the rotor. Most vanes will have some curvature or slant to them and should be positioned so that in spinning the rotor in the direction the wheel will turn (when moving forward), they sling the air away from the center of the rotor to the outside. In other words, the air enters the center of the rotor and is spun to the outside.
In some rotors however, the vanes are straight from the hub to the outer perimeter of the rotor (like spokes on a bicycle wheel). In that case the rotor could be positioned on either side of the car and will perform as designed. In this is the case, and you have slots on the face of the rotor, you can position the rotor to suit your own taste.
Good luck... GUSTO
(Thanks Mike, and great pictures. )
When looking down on the vanes from the top of the rotor the slanted vanes should be pointed to the rear of the car.
My $.02
Sleeper
I agree with Mike's post regarding the direction of the vents. Air is drawn from the center and vented at the outer edge. Shouldn't the slotted rotors be machined so the brake dust and gases are thrown to the outer edge of the rotor? The drilled holes wouldn't matter, as the dust and gases would be drawn into the vents. At least that's how I see it, based on no scientific data.
Mike,
Do you remember what page on StopTech's website you got those picts from? I'm trying to pass along this info - but its more believable if there's a link of info to go along with it.
Thanks!!
(I know this is an old thread, but I remembered seeing these picts and I went back and searched for them again)
