Changing fuel filter?
Old Oct 26, 2001 | 05:41 PM
Vinzvette's Avatar
Vinzvette
Default Changing fuel filter?
How often should this be done and is it difficult? Thanks,
Vince
Old Oct 26, 2001 | 05:45 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default Re: Changing fuel filter? (Vinzvette)
Usually, it should be changed every 15,000 miles, 30,000 miles MAX!!!
Hope this helps you!
Shawn
Old Oct 26, 2001 | 05:54 PM
COOL Z06's Avatar
COOL Z06
Default Re: Changing fuel filter? (L.A.P.D.)
Thanks for the reminder............. :)
Old Oct 26, 2001 | 06:12 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
What kind of fuel filter should we use? And who carry them? PepBoys?
Old Oct 26, 2001 | 06:18 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Default Re: Changing fuel filter? (leanhtuan)
leanhtuan,
Use the factory fuel filter. When dealing with something like you really should install an AC Delco fuel filter.
Just my opinion and will save your warranty if your fuel pump dies.
Shawn
Old Oct 26, 2001 | 07:55 PM
Vinzvette's Avatar
Vinzvette
Has anyone changed thier own, is it hard, what is the prcedure?
Old Oct 27, 2001 | 05:06 AM
FRPTech's Avatar
FRPTech
Vinzvette,
Replacing the fuel filter is a little messy, but, not terribly difficult...
You will need a fuel line disconnect tool and handy socket set...
- Relieve the pressure in the fuel line at the rail.
- Disconnect the battery
- Raise the drivers side rear of the car
- Since you have an A4 as I do, space it tight and it helps if you remove the catback portion of the exhaust on the drivers side.
- The filter is just up under the frame in front of the drivers side rear wheel
- Remove the bolt holding the filter assembly to the frame
- This is where it gets messy... Remove the two quick connect fittings towards the rear of the filter, just squeeze the blueish colored tabs and pull the two lines from the rear side of the filter. DO NOT be right under this - a couple of cups of gas will come pouring out - trust me I got soaked...
- Using the fuel-line disconnect tool, remove the line on the front side of the filter. This is tight, I was worried about snapping the line when I did mine but it will come out... Again, some gas will pour out and remember the filter itself is full.
You MUST use the fuel-line disconnect tool here. Its a little plastic ring with a cutout and tail that slide between the connector on the line and the hard tab on the filter. Same tool is used if you ever remove the line from the fuel rail...
- Clean up all of the fuel that went everywhere
- Put the new filter in place and bolt it down.
- Reconnect the lines.
- Reconnect the battery
- Turn the key in the ignition to pressurize the lines but do not start
Do this two or three times
- Check for leaks
- Replace the catback if you remove.
- Lower the rear of the car.
- Take it for a spin :)
Its not too bad, takes me about an hour and I take my time...
FRPTech
To Changing fuel filter?
