catback keeps moving on me
Old Jun 17, 2007 | 06:05 PM
Dylan 93Z's Avatar
Dylan 93Z
Default catback keeps moving on me
For some reason the mufflers/catback on my car keep moving and i need to continually push them back into place and attempt to tighten the bolts on the muffler clamps. Any other possible causes? Thanks.
Old Jun 17, 2007 | 06:08 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
Mine are doing that too....soon, there will be a visit to my friendly muffler shop for some spot welding....that'll fix it.
Old Jun 17, 2007 | 08:11 PM
Cpig's Avatar
Cpig
I had the same problem after I installed mine. The problem was that I had the clamp too far up on the pipe. There are slits cut lengthwise in the pipes where they join the mid pipe. Make sure the clamps are over the slits and not too deep on the pipe (past the slits).
Old Jun 19, 2007 | 01:14 AM
afone's Avatar
afone
I've got the same thing goin on too... everytime I walk back to my car I give the right side a little lift with the foot wedge. It's getting old. If the roads werent so bad here it wouldnt be a problem but every crack and pothole makes it drop a little bit. I like the spot weld idea... yeah... think i'll do that.
Old Jun 19, 2007 | 07:15 AM
trussme's Avatar
trussme
Default "Here Spot"....
I had to spot weld mine (B &B PRTs or Bullets) have a tendency to slip abit...if you want them to "stay put" that's the best cure. It's a 15 minute job at your local muffler shop or with welder pal...
Old Jun 19, 2007 | 10:59 AM
T Will's Avatar
T Will
St. Jude Donor '13-'14-'15-'16-'17-'18-'19
Mine are moving too but it is not the clamps you can see it flexing all the way to the cats on the passengers side. You can also see the spring hanger flexing. The drivers side is rigid.
To catback keeps moving on me
