Impregnated Polyeurathane bushings
Old Jun 18, 2007 | 08:22 AM
Irish Whiskey's Avatar
Irish Whiskey
Default Impregnated Polyeurathane bushings
Anyone have experience with the graphite impregnated poly suspension busihings?? I guess the idea is to reduce the squeeking always found with the poly bushings.
Old Jun 18, 2007 | 07:22 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
The Hotchkis bars I put on my coupe were already impregnated with grease, and the direction said specifically to not use any more. I haven't heard any noise from them that I know of, but then again I don't hear much else besides my Bullets, stereo, and the added road noise from my steamroller 345s out back (which is more audible than usual because of the custom fiberglass tubs are not as thick as stock).
Old Jun 18, 2007 | 07:52 PM
99blackFRC's Avatar
99blackFRC
I deny having any alleged relations with that Poly Eurathane floosy!
but erm, yeah I'm curious about this too..
Old Jun 18, 2007 | 08:49 PM
MadMaxZ06's Avatar
MadMaxZ06
I also would love to know a definitive answer to this question. I've heard it all:
- Graphite makes a difference
- Graphite doesn't make a difference at all, they still squeek
- All polyurthane bushings need to be greased often it's just maintenance
- They'll make your car ride like a truck
- It will make your car actually ride "better" because you'll have less deflection thereby causing the main suspension components to work correctly
I'm not sure who to believe but I know two things, taking off control arms to gain access to bushings is not a project I'm going to do regularly and #2 if my bushings are constantly squeeking, I'm not going to like it.
- Max
Old Jun 19, 2007 | 12:28 AM
Last C5's Avatar
Last C5
I'm starting to think maybe it's the ride like a truck while squeaking all the while that's closer to the real answer. Nobody seems to jump up and say what a great deal they are and how happy they are to have spent all that labor installing them.
Old Jun 19, 2007 | 08:12 AM
Irish Whiskey
[QUOTE=Last C5;1560727851]I'm starting to think maybe it's the ride like a truck while squeaking all the while that's closer to the real answer. Nobody seems to jump up and say what a great deal they are and how happy they are to have spent all that labor installing them. [/QUOTE
seems you could be right!!
Old Jun 19, 2007 | 04:50 PM
Irish Whiskey
[QUOTE=Irish Whiskey;1560729555]
up this goes!!
Old Jun 19, 2007 | 05:27 PM
C5-vette's Avatar
C5-vette
Old Jun 20, 2007 | 07:19 PM
Blue Angel's Avatar
Blue Angel
So of the thousands of members here nobody has used poly bushings?????????????
Maybe if there's an honest vendor to contribute....
Old Jun 20, 2007 | 07:23 PM
FRCTony's Avatar
FRCTony
http://forums.corvetteforum.com/show....php?t=1698380
To Impregnated Polyeurathane bushings
