lowering Question
Old Jun 18, 2007 | 07:27 PM
JAMESNORTHPROV's Avatar
JAMESNORTHPROV
Default lowering Question
i have installed my new blistiens in the rear and lowered the rear. today i was installing the fronts and was going to lower the front but all that i saw was a stud bolt and no nut to turn. just the clip. any help with this would be great. do i turn the stud. thanks jim
Old Jun 18, 2007 | 07:41 PM
hotwheels57's Avatar
hotwheels57
https://www.corvetteforum.com/techti...D=27&TopicID=1
If you need more information, try keywords "lowering C5" or words to that effect.
Old Jun 18, 2007 | 08:22 PM
JAMESNORTHPROV
there is no nut or head on bolt. it looks to be sq off at the end, is this what i am going to turn. it just a treaded stud.
Old Jun 18, 2007 | 08:37 PM
hotwheels57
What you're describing/seeing is what you get on the C5/Z06. It's just the threaded stud protruding with the retaining clip on the top. You're supposed to use a 10mm open end wrench and make the adjustments. You may have trouble getting the stud to turn due to corrosion and bushing tension against the spring. You may need some penetrating oil and a jack to relieve the tension.
Hopefully, no one else have ever made any adjustments to yours which usually damages the flats on the stud.
To lowering Question
