HELP-air box connection?
Old Jun 19, 2007 | 08:14 PM
C5TORCHED's Avatar
C5TORCHED
Default HELP-air box connection?
I just bought a 98 vert with no front bumper, air pump or air box. I already bought an air box BUT what connects to the 90* nipple that sticks out of the air box. also what hose or hoses connect to the air pump? There is one S like hose coming from the exhaust manifolds on the car, does that go to the air pump? HELP
Old Jun 19, 2007 | 08:44 PM
hotwheels57's Avatar
hotwheels57
Your oem air filter assembly will connect to the air pump via the 90 degree plastic nipple.
Old Jun 19, 2007 | 11:26 PM
C5TORCHED's Avatar
C5TORCHED
So the air pump has 2 hoses -1 hose to the air filter 90* elbow and the 2nd hose goes to the exhaust hose, coming from exhaust manifold?
Old Jun 20, 2007 | 01:52 PM
C5TORCHED's Avatar
C5TORCHED
Anyone?
Old Jun 20, 2007 | 03:35 PM
SilvaDragon's Avatar
SilvaDragon
Originally Posted by C5TORCHED
Anyone?
There is a valve attached to a metal pipe off the driver's side
exhaust manifold, with a rubber hose coming off of it. That
joins to another hose that goes around the back of the motor
to another valve, then on to the passenger side exhaust
manifold. The rubber hose that joins those two goes to the
air pump.
Depending on what year air box you got, the hole for the
hose with the 90-degree fitting on it may be on the side,
on top, or there may be no hole at all. If you got the '99
box, it should be on the side of the driver's side of the box.
There should be a rubber grommet that holds that 90-degree
fitting in that hole.
Hope that helps!
To HELP-air box connection?
