Can't find this code
Old Jun 20, 2007 | 12:16 AM
jjk2509's Avatar
jjk2509
Default Can't find this code
My car is showing code 60 MSD.
Does anyone know what this means?
Thanks in advance for your help.
Old Jun 20, 2007 | 12:51 AM
jjk2509's Avatar
jjk2509
Wrong code, here is the one I cannot find on my code list.
58 SDM - NO COMM.
Old Jun 20, 2007 | 01:36 AM
BlackZ06's Avatar
BlackZ06
58 SDM - NO COMM.
Means the SDM (the module that controls the airbags) is not responding when you ask the systems to list their codes. If the SDM is not communicating with the other modules, your SIR light should be on and the airbag system is disabled.
Old Jun 21, 2007 | 07:53 PM
jjk2509's Avatar
jjk2509
The SIR light is not on. I removed the airbag to replace the steering wheel. Would this cause the code to appear?
How do I get it to reset?
Old Jun 21, 2007 | 07:59 PM
corvettedoug's Avatar
corvettedoug
Just access the code in manual diagnostics mode on your dash(I assume this is how you checked the code). Go to the code and press the reset button on your dash.
Old Jun 21, 2007 | 08:06 PM
Bill Dearborn's Avatar
Bill Dearborn
Based on your comment that you removed the air bag you should see a code of B0026 (Circuit Open) however, you also state the On Board Diagnostics indicate the SDM module isn't communicating with the system so you may have lost the module (let the smoke out of it) while playing around with the air bag.
Bill
Old Jun 21, 2007 | 08:37 PM
jjk2509's Avatar
jjk2509
Bill
Bill,
"Let the smoke out of it" what does that mean and how do I fix it?
Old Jun 22, 2007 | 07:42 AM
jjk2509's Avatar
jjk2509
Any help?
Old Jun 22, 2007 | 10:19 AM
BlackZ06's Avatar
BlackZ06
Bill's saying you MAY have damaged the SDM when you played with the airbag. The SDM is designed so that if it thinks an airbag has "fired", the SDM is PERMANENTLY locked. If it is locked, it has to be replaced. Also, replacement requires a Tech2 as the SDM has to have the vehicle's VIN number programmed in it, and the BCM has to be updated with the new SDM's SIR serial number. If these steps aren't taken a B1001 will set and the airbag system will be disabled until the problem is fixed.
To Can't find this code
