driving/turn signal light
Old Jun 21, 2007 | 12:54 PM
oh6driver's Avatar
oh6driver
Default driving/turn signal light
ok will someone please tell me how to replace my turn signal/driving light on the drivers side without removing the entire front end. i cannot see how to take it out. there is no screws on the lens to remove it and it is blocked in by a bottom cover. i have a 1999 coupe. i do not want to take it to the dealer $$$$$ to fix it. any suggestion will be a big help. thanks scott
Old Jun 21, 2007 | 02:50 PM
Slotcar's Avatar
Slotcar
This is not too hard according to my service manual set. Remove the closeout panel that is under the fascia on the affected side(2 bolts). Release the brake cooling duct from the front fascia. Remove the spring on lamp housing and the 2 retaining screws on the bottom. Disconnect the sockets and in your hands it should be! Hope this helps.
