Radiator hose change
Old Jun 21, 2007 | 06:42 PM
crause's Avatar
crause
Default Radiator hose change
I am about to change both of my radiator hoses on my 2000 with 14k. The top hose looks very easy. I can not see the radiator end of the lower one. How is this accessed? If I take off both of the hoses, can I assume that most of the fluid will drain out? I need to know so when I figure the replacement mixture it will be correct. ?
Old Jun 21, 2007 | 07:41 PM
Bill Dearborn's Avatar
Bill Dearborn
When you pull the bottom hose there will still be coolant in the block. The only way to get it out is to put everything back together and flush the system with clear tap water until the discharge is clear. Then drain as much as will come out close the drain valve and add your antifreeze in the correct amount and top off with clear tap water.
Bill
