Transmission Pan part numbers/advice
Old Jun 22, 2007 | 01:15 PM
foggy's Avatar
foggy
Default Transmission Pan part numbers/advice
I would like to put a new trans pan on my 2000 A4 Vert.
TCI gave me 2 part #
378000 deep cast alum. pan 2 extra qt capacity
378015 deep cast alum pan 3 extran qt cap with temp port and black
heat dissapating coating.
When I look these up on Jegs website, it has notes: Not for use
with C5/C6 corvette with filler tube in pan.
Any advice???
Will either of these work for me, or is there another mnfr that
makes a deep cast pan for us C5 ers.
Tom
Old Jun 22, 2007 | 04:11 PM
foggy's Avatar
foggy
Anyone replaced their trans pan with an aftermarket one???
Old Jun 22, 2007 | 04:14 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I'm most positive I have the 2 extra qt pan part# 890-378000 from Jegs,It fits fine.The only thing I had to do was drill a hole in the side and put a trans pan drain plug kit from Jegs part# 555-60175 so I can check fluid level.And there is this one http://www.yourcovers.com/tp_8650-3.shtml
To Transmission Pan part numbers/advice
