Finally Solved My Abs Brake Problem!!!
Old Jun 22, 2007 | 01:47 PM
2000BSME's Avatar
2000BSME
Default Finally Solved My Abs Brake Problem!!!
I think...
Thanks to Bill Curlee and the others who've helped me. A little history:
I've been having the service abs/trac. cont./act. handling warning for about 8-10 months, and I actually think it happened BEFORE I installed my Russel stainless braided brake lines, but I can't remember for sure.
I tried cleaning connections, swapping pigtails, replacing wheel bearings...
Well I finally decided to do what was suggested in another thread, put GROUND wires from the frame to the caliper, and that seems to have worked! Not a single problem since then.
Old Jun 22, 2007 | 03:15 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
How did you secure the wires to the calipers?
Old Jun 22, 2007 | 03:50 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
It's from the SS brake lines not grounding out, they build up a static charge and throw off the wheel speed sensor... I had this issue when I first installed my Goodridge SS lines. I then swapped them out for Goodrige SS lines w/ AN fittings and no more issues.
Old Jun 22, 2007 | 06:33 PM
2000BSME's Avatar
2000BSME
Unscrewed the floating bolt mechanism, and put a ring terminal behind it, and screwed it back in.
To Finally Solved My Abs Brake Problem!!!
