Header Air tube?
Old Jun 23, 2007 | 01:19 AM
SLPRC5's Avatar
SLPRC5
Default Header Air tube?
I had a set of LG LT headers installed on my '97 C5.
The headers seem to be for a 2001 and later because the air tube is on different cylinders.
The one air outlet on the driver side is hooked up, but the one on the passenger side is caped off at the header and caped off at the tube that goes to the header.
My question is; is there an adapter for the passenger side to hook up the air tube?
Thanks,
Sleeper
Old Jun 23, 2007 | 01:38 AM
MawneeC5's Avatar
MawneeC5
Usually to use the wrong year headers requires you replace the air tube coming from the back of the engine to the header with the matching year version.
Me, I just removed the entire air system and had it tuned it out. A couple of block off plates and the headers and I've got more room to work with under the hood
Old Jun 23, 2007 | 01:44 AM
SLPRC5's Avatar
SLPRC5
That would work for sure, but not in the Smog Police state of Cali. So all I have to do is get the right air tube for the passenger side and I'm set.
Thanks..
Old Jun 23, 2007 | 04:51 PM
Vettedreamer2's Avatar
Vettedreamer2
Not sure if this will work for you, but I just cut pipe attached to headers and put a peice of rubber high temp hose to span the differnece and clamped each end with hose clamps and called it a day.
To Header Air tube?
