Difference between head stud kit and main stud kit?
Old Jun 23, 2007 | 10:14 PM
spiral04's Avatar
spiral04
Default Difference between head stud kit and main stud kit?
I am looking at getting some ARP bolts for my upcoming head and cam project. What's the difference between the head stud kit(234-4317) and main stud kit(234-5608), and which one do I buy?TIA
Jason
Old Jun 23, 2007 | 11:06 PM
Tom Porter's Avatar
Tom Porter
I you are changing the heads use the head stud kit. The main studs are for your crankshaft main bearing caps. Keep in mind I dont think you can install or remove your heads with the stud kit with the motor in the car because of clearance issues. If it were me I would upgrade to new ARP head bolts.
Old Jun 23, 2007 | 11:28 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Sure you can, there's plenty of clearance to slide the heads on over the studs.
Old Jun 24, 2007 | 12:08 AM
spiral04's Avatar
spiral04
So are you guys saying that I should buy the head stud kit? I was going to buy the harmonic balancer bolt for the asp pulley. While I'm in their, any other(crank?) ARP bolts I should buy?
Old Jun 24, 2007 | 01:36 AM
RonSS's Avatar
RonSS
Hey Jason,
I talked with you on the Lone Pine run a few weeks ago and if I remember right your doing heads and cam, nothing in the bottom end. No need for Main studs then. If you want to use studs for the heads then yep, get the head stud kit. The only stock bolts you can’t use over on a LS1 head and cam swap are the head bolts and the crank/balancer bolt.
Old Jun 24, 2007 | 01:53 AM
spiral04's Avatar
spiral04
Originally Posted by RonSS
Hey Jason,
Hi Ron
Yes you are correct, not doing anything on the bottom end. ARP had sent me an email saying to buy the main stud kit. I was about ready to get the head stud kit, so the email had me confused. I have a friend of a friend who works for ARP, so I only want to bother them one time. Hopefully I'll be getting a deal! Hope all is well with you.
To Difference between head stud kit and main stud kit?
