Damn fuel leak..........
As I have read on here before.......sometimes after ~10 years the o-rings on GMs stupid plastic fuel connectors leak, I could see that was my issue on the outlet side of the fuel filter. When I had the drivelline out I said, "If it ain't broke, don't fix it"...not leak and it looked good, I didn't touch it... Well........oh,well
Its a PITA to get to with 3" exhaust.....
Jacked it up, dropped the rear sway bar,took off the DS exhaust cat-back
The inlet side has a green rag in it, the outlet a clear plug you can just see to the left of the shield bolt.......
I didn't think a 97' fuel filter would be hard to find............NAPA was the only one, so I put it on for $14.95. No bracket, but I think between the heat and vibration of mouting to the frame.......that makes them leak.
Put in on, started it with one open exhaust
...no leaks.All back together and seems fine.
I will take the leak today though................sure beats a leak at the track
Mine started leaking also (1998). The bolt holding bracket fell off, I had to expoxy it to frame! I used a GM replacement fuel filter.
BTW, the MN6's are easier to get to.
Is the NAPA made of metal? It doesn't look like the one end has a plastic lock fitting, what gives?
