Dic Code Help??
Jun 24, 2007 | 12:34 PM
Dic Code Help??
New long tubes, got codes: P0140 and P0160
P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2 and P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
I assume that is the lack of rear 02 sensors, but I also got codes
C1247 & C1248 but I can't find them listed on stengel.net. Does anyone know what those codes are??
Jun 24, 2007 | 01:35 PM
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Jun 24, 2007 | 07:02 PM
C1247 low brake fluid level
C1248 one or more faults have been detected in the EBCM in the ABS/TCS system
Jun 24, 2007 | 11:26 PM
Thanks, where did you find it??? I turned the car to on, not started when I was doing the brakes...
