Traction Control, and Abs problem
Old Jun 24, 2007 | 10:55 PM
fastfb350's Avatar
fastfb350
Default Traction Control, and Abs problem
every once in a while when I get in and fire up the car, the "service ABS" and "Service Traction Control" warnings come up, and the dash lights come on. I have a feeling that my module is going out? any thoughts or experience?
Old Jun 25, 2007 | 01:49 AM
bdiddo's Avatar
bdiddo
Default ABS problems
Seems like we all have them (sooner or later). First you need to check your DIC readings. That will help point you in the right direction for further analysis. I would suggest do a search on the forum and you will come across a ton of info (seach ABS or EBCM). You want to start with the by Bill Curley (very informative).
If it does out to be C1214 reading you may want to consider contacting ABSFIXER. Mine is heading there this week as I a just removed the EBCM. For what I've read, he has an excellent track record of repairing the unit for $150 (vs. dealership at $900+).
Hope this helps
Old Jun 25, 2007 | 06:18 AM
trussme's Avatar
trussme
Default Here's help...
I have a complete file (with photos) on how to check, remove/install & where to get it fixed (for $150 )...just PM me your email address. Bill
Old Jun 26, 2007 | 04:13 PM
fastfb350's Avatar
fastfb350
It is C1214 . At least I know what it is now.
Old Jun 27, 2007 | 02:49 AM
BowTieRocket's Avatar
BowTieRocket
Before reaching for your wallet, look at Bill Curlee's post on electrical stuff. It's a sticky at the top of this forum. The grounds on these cars can be a problem.
I had an intermittent like you're describing, plus some other odd symptoms. Cleaned the ground connectors up on the top of the frame rails behind the headlights (see Bill's post for pictures), and haven't had a repeat. The ground for the EBTCM is somewhere in that mess, at least on the 99 and later cars, and some of the 98s.
Cleaning the grounds wasn't a tough job. I also put a bit of AlCu (Aluminum to copper splice compound) on the nut and stud where they attached, as the nut and stud look to be brass or copper, and the lugs are aluminum. These metals set up a chemical oxidation - houses wired with aluminum wire have bee known to have problems with this. I also coated the pins and housing of the connector with dielectric ("tune-up") grease to help with moisture.
No guarantees, but it's good maintenance, the grease and compound won't cost you the price of a good cigar, and it may fix your problem.
Old Jun 27, 2007 | 07:30 PM
TJason25's Avatar
TJason25
yea, I just had mine replaced on Monday. pricey..
Old Jul 2, 2007 | 03:25 AM
californiakid's Avatar
californiakid
My system just lit up like a Christmas tree this morning. But it came on after we started having some bad rainfall, I wonder if this caused when of the sensors to get wet and set the fault code. I will clear it later on today with Predator and see if it comes back. If it does, I will be doing the $150 mod myself, no way I am paying GM 1250 to replace it.
Californiakid
Old Jul 2, 2007 | 06:32 AM
trussme's Avatar
trussme
Default Help is on the way....
Californiakid
CalifKid, just emailed my how-to & where-to-fix-it file to you. Good Luck! Bill
Old Jul 2, 2007 | 02:42 PM
californiakid
Trussme,
Thanks. I was driving home today on the autobahn and the all of the lights were lighting up and going out, no rain this time. It was like it is a short or something. Then something bad happened to tell me that maybe my stuff might be broken, the brakes were pusling when I was slowing down, and the more I psuhed into them, the more they pulsed, they never did this before, so I am thinking perhaps something is wrong for sure.
californiakid
To Traction Control, and Abs problem
