Rear rotors!!!
Old Jun 25, 2007 | 11:41 PM
TheDEfan's Avatar
TheDEfan
Default Rear rotors!!!
I bough a 98 with 16,000 miles on it and the parking brake needs either new shoes or a adjustment but the damm rotors are rusted and stuck to the hub and won't come off. I used deep creep and rubber mallet and beat on them for about and hour then gave up on it. Maybe I need a harder mallet?? Any ideas anyone? I have giant gear puller but I'm afraid of bending or breaking the rotor.
Old Jun 26, 2007 | 12:02 AM
Jim Taylor's Avatar
Jim Taylor
I've read on the forum that some people put the wheels on with the lug nuts loose. They drive the car a few feet and let the wobbly wheels pop off the rotors. Sounds a little iffy to me, but that's what I've read.
BTW, you do have the e-brake off right?
Old Jun 26, 2007 | 12:07 AM
jor8888's Avatar
jor8888
parking brake off?
Old Jun 26, 2007 | 12:08 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
A bigger hammer solves a lot of problems. a few have used a torch to heat it up, then beat it again
Old Jun 26, 2007 | 12:30 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by jor8888
parking brake off?
Old Jun 26, 2007 | 01:02 AM
rws.1's Avatar
rws.1
There is likely some corrosion present or the pads have worn into the inside of the rotor, crating alip that is difficult to get past.
PB blaster on the area between the studs and the rotors, ensure the parking brake is off. ( and alos the factory installed star locking washers)
Get a large ubber mallet and hit inside of back of rotor
outside of front, incied of bottom, outsdie of top etc... alternating around the rotor.
It will eventually free up.
Old Jun 26, 2007 | 08:58 AM
TLewis4095's Avatar
TLewis4095
Find a big empty parking lot and while backing up keep pulling up on the parking brake lever. Each time you pull it up the brake should self adjust. Should is the catch....if not you need to get the rotors off & adjust the star adjuster. The pads will still be fine.
Old Jun 26, 2007 | 09:16 AM
Secret237's Avatar
Secret237
Often there are 2 threaded holes in the flange area of the rotors ( I don't know if this is the case on the C5 though )
You can put 2 bolts into these threads holes and push the rotor off.
Good luck.
Old Jun 26, 2007 | 09:20 AM
Bad Machine's Avatar
Bad Machine
From: Rude, Loud and Aggressive! ECS Twisted Racing, "How fast do ya wanna go?"
Also make sure the retainer clip is removed. Then get a BIG dead blow hammer!
Old Jun 26, 2007 | 09:30 AM
TheDEfan's Avatar
TheDEfan
parking brake off?
Oh yea.
To Rear rotors!!!
