Tech info needed- Z06 upgrades?
Old Jun 26, 2007 | 10:15 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Default Tech info needed- Z06 upgrades?
Hi all.. need some general info..
purchased my 00MY coupe a couple of years ago, and was thinking of some performance upgrades..
Are the Z06 brakes, suspension, sway bars better and how so..Larger calipers & rotors?? Thicker say bars?? Higher rated spring/shocks?
thanks..
Old Jun 26, 2007 | 12:39 PM
Blown 346's Avatar
Blown 346
thanks..
I'll give this a shot.
Im not the best witht he vette stuff yet, so I'll give you info on what I know. I know the Z06 does have upgrades in suspesion over a normal Coupe. I believe the shocks are different, Im not positive on the sway bars thickness. I also think the brake rotors are the same size with both vehicles.
Unless you are getting parts from a Z51 car with the fully upgraded suspension, Only then would I htink all might be differnt. Dont hold to this though.
Old Jun 26, 2007 | 01:45 PM
MattB's Avatar
MattB
Check out this web site, some good info. But why go to the bother of Z06 parts? Not much of a difference.
http://www.jakelatham.com/c5/misc/faq.shtml#2-1
Old Jun 26, 2007 | 03:08 PM
02gt350's Avatar
02gt350
true, they arnt. But they are a good price. Brakes and rotors are the same. Shocks are a bit stiffer. 04's are the best. and sway bars are a decent improvment over stock. cant beat 220 shipped with new end links and bushings
Old Jun 26, 2007 | 07:44 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Default Z51 coupe
My car has the Z51 package...
so basically the expense/effort is not worth it as it may be a nominal upgrade at best???
Old Jun 26, 2007 | 07:51 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Default Z51 coupe
Old Jun 27, 2007 | 12:24 AM
Last C5's Avatar
Last C5
The Z06 front sway will make a difference, your rear sway is the same as a Z06. There is only about 10% difference in your rear spring and a Z06 and the front spring is the same. Do the front bar now and some C6Z06 shocks now or later. Been there - done all this.
Old Jun 27, 2007 | 11:45 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
thansk for the info.. saved me alot of time and probably money..
To Tech info needed- Z06 upgrades?
