Gear Question - Not Your Typical One
Old Jun 26, 2007 | 12:12 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
Default Gear Question - Not Your Typical One
I've been thinking of doing gears, either 3.90 or 4.10s for my 01 coupe. While I understand how they give you great gains on the butt dyno, especially with throttle respone, I have some other questions about them.
They allow the engine to get into it's powerband quicker, but doesn't this also mean that you'll be shifting more frequently. Wouldn't this then mean that you are spending less time "under power", which can't be a good thing?
Old Jun 26, 2007 | 12:18 PM
Blown 346's Avatar
Blown 346
You will be shifting sooner than normal depending on what size gear you have. I think with time the car is under power it evens itself out since you are still giving the car the basic same amount of power, but you go thru the gear faster.
Old Jun 26, 2007 | 01:10 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Upgrading the gears makes the tires spin slower. The reduction in RPM comes with a corresponding increase in torque at the wheels. So if you go from 3.42 to 4.10, thats ~20% increase. So your RPMs will be 20% higher to go the same speed, and the torque at the wheels will be 20% higher. Overall, you haven't changed power since power=torque x rpm.
But you do run out of top end since the engine has to rev higher to go equivalent speed.
You absolutely will have to shift more freqently. In fact, going too low can hurt 1/4mile times if you have an extra shift in the run.
Sure is fun to roast the tires, though
Old Jun 26, 2007 | 01:37 PM
99C5JA1's Avatar
99C5JA1
With as much as gears cost in these cars, I'd be sure it's what you want long term. I had planned on going with 3.90's in this car, but with it's current power level I can't use 1st gear as is. Perhaps after I switch to Nitto R2's I'll change my mind. But for now the last thing I need is lower gearing.
Old Jun 26, 2007 | 02:12 PM
SLO C5's Avatar
SLO C5
Cruise-In X Veteran
St. Jude Donor '09
Good point, I had thought of this as well. I'd hate to spend $1500-2000 on a set of 3.90s or 4.10s, then do H/C or FI with over 450rwhp and have no traction through the 1st 3 gears.
Old Jun 26, 2007 | 03:25 PM
Face's Avatar
Face
It's called learning how to drive again.
If you plan on going FI, don't go with 4.10's.
Old Jun 26, 2007 | 05:03 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default What Traction?
I've got 4:10's and I like them. I can use 6th gear without going a gizillion miles an hour. With the 3:42's the car would drone in 6th below 75mph.
BTW, I've got 460 rwhp and you just need to be careful when taking off in any gear below 3rd.
Bob K.
To Gear Question - Not Your Typical One
