Blackwing installation help
Old Oct 28, 2001 | 06:18 PM
curvett's Avatar
curvett
Cruise-In III Veteran
Default Blackwing installation help
When a blackwing is installed should the panel under the filter be cut out? Also, should a hood seal be used?
Old Oct 28, 2001 | 06:32 PM
wstory1's Avatar
wstory1
Default Re: Blackwing installation help (curvett)
You only cut out the bottom panel if you buy the cold air cover to go with the Blackwing. A hood seal isn't necessary but helps keep the exposed filter cleaner. If you go with a cold air cover you don't need the seal at all.
Old Oct 28, 2001 | 06:37 PM
skip89's Avatar
skip89
I just put mine in, don't need to cut anything. I have a hood seal only to keep water off the filter element. Also don't open the hood with water on it because it will run down on the filter. Do a search, there are very detailed directions with pictures here somewhere. Take your time and keep the clamps loose untill you line up everythlng, like gromets on top of the radiator, the ones that hold the air bridge in place. The problem for me was when I left the clamps loose to align the grommets it all kept coming apart. Be patient take your time. Good luck, Skip :chevy
Old Oct 28, 2001 | 07:11 PM
curvett's Avatar
curvett
Default Re: Blackwing installation help (skip89)
Thanks for the info guys.
To Blackwing installation help
