check engine light
Old Jun 27, 2007 | 11:50 AM
77Stingray99's Avatar
77Stingray99
Default check engine light
I have a 99 c5 and I have a check engine light on all the time. The service engine soon display shows up every once in a while, while I am driving. I checked to see what the code was and it said I have an EMISSIONS EVAPORTION LEAK. Now I have talked to some people and they all tell me to see if my gas cap was on tight. I have done this and it is fine. Is there anything that I could visiually see to help me with this problem. ANY HELP PLEASE.
Old Jun 27, 2007 | 11:58 AM
dougbfresh's Avatar
dougbfresh
Could be several things. I would look at the vacuum hoses from the engine to the evap canister 1st. Probably one is cracked and leaking.
Old Jun 27, 2007 | 12:15 PM
77Stingray99
where is the evaporator canister located?
Old Jun 29, 2007 | 10:47 PM
corvettedoug's Avatar
corvettedoug
Did you reset the code and it came back after tightening your gas cap?
To check engine light
