Wipers do not shut off
Old Jun 28, 2007 | 07:33 AM
leetownreb's Avatar
leetownreb
Default Wipers do not shut off
Replaced motor--udders were like new. Anyone know of a good dealer/mechanic in the Charles Town, WV area?
OR, is the stalk easy to replace? Help!
Old Jun 28, 2007 | 09:08 AM
roscoe118's Avatar
roscoe118
Does it spray washer fluid (at least until the reservoir runs dry) while the wipers run?
The "fluid control" button at the end of my stalk flew off which caused the wipers to go on, and spray the windshield. Check the end of the stalk if that is the case. I was lucky, and able to find the button and springs sitting in the passenger seat, and door seal.
If the wipers are running without fluid spraying, then it could be that your wiper motor is wet from the drain "udders" being clogged.
Good Luck
Old Jun 28, 2007 | 03:02 PM
leetownreb's Avatar
leetownreb
Default wipe motor
everything around the motor and the udders were spotess!
any other ideas?
Old Jun 28, 2007 | 09:31 PM
busto's Avatar
busto
I had the same problem. Turned out to be the wipe switch. The one on the colum. I paid around $90.00 for mine through Autozone.
To Wipers do not shut off
