bleeding brakes with ABS
Old Jun 28, 2007 | 10:00 AM
jawzforlife's Avatar
jawzforlife
Default bleeding brakes with ABS
I need to replace my power steering pump. And inorder to get the pump out, i need remove the ABS brake system infront of the engine.
I've been told I might need a pressure bleeder to re-bleed the lines after I reinstall the ABS system.
Do I need a pressure bleeder, or can you do it just the "old fashion" way with the pedal?
This is for my 1999 Vette
Old Jun 28, 2007 | 10:11 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default You don't need to disconnect the ABS
You don't need to remove the ABS unit to replace the PS pump. There is a bracket that attatches the ABS unit to the front crossmember. Remove that and your almost home free!
Bob K.
Old Jun 28, 2007 | 10:19 AM
jawzforlife
So I can leave the ABS unit attached to all the brake lines, I just need to undo the bracket the holds the the ABS unit to the cross member. Then do what, bush the ABS unit towards the front of the car? There is enough play in the lines to do that?
If I do it that way, is there still room to get the pulley puller in there to get the P/S pulley off?
Or can I get the P/S pump out without taking the pulley off first?
Old Jun 28, 2007 | 12:50 PM
Bull_in_a_china_shop's Avatar
take off belt, alternator, top radiator hose and ps pump reservoir.
unfortunately it takes forever to unbolt the PS pump, bolts can only turn like an eighth of a turn etc. rent a ps pulley puller at autozone, use the long needle attachment. Lots of guys break the pulley removing, and its $20 to replace. I got it all at gm parts direct, very reasonable. Just leave the ABS hanging by the lines in the car
To bleeding brakes with ABS
