Air bridge ?
Old Jun 28, 2007 | 03:59 PM
ace1's Avatar
ace1
Default Air bridge ?
Just purchased a cabon fiber air bridge with no sensor fitting from a forum member, my stock air bridge on a 1999 has a sensor glugged in to the left side, what its for I don't know, may be some one can help,do I need it? Thanks All
Old Jun 28, 2007 | 04:02 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Sounds like the Intake Air Temp sensor.......just drill the bridge in about the same place and swap it...........
Old Jun 28, 2007 | 04:22 PM
fixvet's Avatar
fixvet
You definitely need it! Just drill a hole and transfer the grommet then plug in the IAT sensor.
Good luck
Old Jun 28, 2007 | 05:20 PM
99C5JA1's Avatar
99C5JA1
It's the Intake Air Temp sensor. And yes you do need it. The PCM uses this to adjust all sorts of parameters. You have 3 options here.
The first is to put a hole into this airbridge and install the sensor (making sure it's sealed). You'll also probably need to adapt the inlet to your smaller MAF sensor.
The second is to switch to an '01+ 85mm MAF sensor calibrated for your '99 and use a 3 to 5 wire MAF adapter harness. The '01+ MAF has the IAT integrated so a separate sensor is no longer needed (this is why your airbridge does not have the hole to begin with, it is designed for an 01+ car). You may or may not need to adapt the air cleaner to this depending on which one you have.
The third option is option #2, but with a non calibrated '01+ 85mm MAF. This requires having someone change the tables in the PCM. This is to me is the proper way to do it.
Old Jun 28, 2007 | 05:39 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
i went through a similar procedure with my 97. getting the sensor out without damaging it is a pain, but doable. If you have precision flathead screwdrivers and a sharp probe set, you can also re-use the rubber mount it comes with. I'd also reccomend siliconing the outside with black silicone just to make sure it's leak free.
Old Jun 29, 2007 | 09:09 AM
ace1's Avatar
ace1
Very helpfull, Thanks all
To Air bridge ?
