C5 question
Old Jul 2, 2007 | 08:16 PM
chiavet's Avatar
chiavet
Default C5 question
was cleaning the vette today for a July 4th parade, It is a 2001 with an automatic transmission. Pulled it into garage. Later pulled it out to wipe down the zaino 5 I had put on earlier. When it was started to put it back in the garage the dash read "Service Column Lock" Looked in the owners manual and it said it only pertains to manual tranmissions.
Has anyone else with an auto. trans. of roughly the same year had this happen? What did you do?
Old Jul 2, 2007 | 08:31 PM
johninar's Avatar
johninar
You might want to check the column lock sticky thread.
http://forums.corvetteforum.com/show....php?t=1312929
Old Jul 2, 2007 | 08:41 PM
chiavet's Avatar
chiavet
just got off the phone with the dealer. Gave them my vin#. They said my Vette was not included in the recall.
Old Jul 3, 2007 | 10:02 AM
jovette's Avatar
jovette
They are not current with the GM recall on this. Read the sticky at the top of this section, order a CLB, install it, and be done with this problem, once and for all time.
Old Jul 3, 2007 | 10:27 AM
Double_Trouble's Avatar
Double_Trouble
Default Service Column Lock
I called the dealership on mine and they told me the recall had already been fixed on mine,(I bought my car used). The moral of this post is:
There is a chance the Column Lock will come back after the recall is fixed.
My solution: I ordered a Column Lock Bypass from ThunderRacing. Simple to install and you will never run into that problem again. I paid around 60 bucks shipped to my door. It comes with complete instructions on how to install it. The bypass is like the size of a square battery. Look into it and good luck
Old Jul 3, 2007 | 10:33 AM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Old Jul 3, 2007 | 10:53 AM
Bob CTS's Avatar
Bob CTS
The general consensus is to not deal with the dealer, simply stated their so called fixes do NOT work. Order the CLB and be done with it.
Old Jul 3, 2007 | 09:17 PM
ROJ#79's Avatar
ROJ#79
I had the recall done at a local dealer 3 years ago when I bought my '99.
Not a problem with the service or the work!-
Old Jul 3, 2007 | 09:30 PM
TEXHAWK0's Avatar
TEXHAWK0
It is a 2001 with an automatic transmission. Looked in the owners manual and it said it only pertains to manual tranmissions.
2001 and newer automatics did not come with a locking column, so I am not sure why you are getting the error message.
I assume your column did not lock before OR after this happened?
To C5 question
