L92 heads on a LS1
Old Jul 5, 2007 | 11:06 PM
FL1BY's Avatar
FL1BY
Cruise-In IV Veteran
Default L92 heads on a LS1
Can L92 heads be used on a stock bore LS1? I know the intake will be changed also. I can not go the entire route of the short block at this time, but I want to get the heads and intake and use them on the current LS1. Cam will be changed also...
Old Jul 5, 2007 | 11:46 PM
myk7's Avatar
myk7
Nope, the bore is not big enough
Old Jul 6, 2007 | 12:17 AM
edcmat-l1's Avatar
edcmat-l1
I think somebody has a L92 for 3.9 bores. Originally they were not made for them, but I believe someone has a set now.
Question is though, why would ya want that big azz port on a 347? I'd stick with smaller cathedrals. You'll make better power with less of a cam.
Old Jul 6, 2007 | 06:56 AM
WKMCD's Avatar
WKMCD
Someone hinted about GM producing small bore L92 heads but I think it's wishful thinking. I don't think GM is going to do the work for a very limited application.
Throw set of ETP 215's on there.
Old Jul 6, 2007 | 07:16 AM
Bville-Bud's Avatar
Bville-Bud
St. Jude Donor '05-'06-'07-'08
Through a set of ETP 215's on there.
A couple of months ago GM High Tech Performance magazine reported that a small bore L92 was in the works from the General. If GM is engineering the heads I'm sure they will factor in port size and compression ratio's.
Old Jul 6, 2007 | 07:27 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
A lot of people use them on Turbo motors because it drops the compression to the desired ratio.
They flow real good and work best in this application.
If your looking to do a head change I'd go with Patriot Heads or a set of TFS heads and a nice cam to compliment it or if you're going to do a Turbo set-up then go with the L92's!
Thanks,Matt
Old Jul 6, 2007 | 10:44 AM
edcmat-l1's Avatar
edcmat-l1
YEP. ETPs.
Old Jul 6, 2007 | 10:47 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Only on a 4" bore for now
Thanks,Matt
L92 heads require a 4" bore. I don't think the small bore heads are out there.
Bob K.
Old Jul 6, 2007 | 12:12 PM
kromberg's Avatar
kromberg
I am pretty sure there is not a 3.9" bore version of the L92 head. I know ETP made a 'small' bore version of the LS7 head, but that also requires a 4.0" bore.
Keith
Old Jul 8, 2007 | 12:25 AM
FL1BY's Avatar
FL1BY
Thanks everyone. I wanted to upgrade the intake side, but only buy heads once, because a 4.00+ bore block is in the future. Guess I should just build now, sell and build again later.
Again thanks for the input.
To L92 heads on a LS1
