TECHS....passenger door lock trouble?!?!
I saved this from an older post: someone's instructions on how to remove the door panel, looks like some great detail...
"Remove 2 screws behind the pull handle, pry the release handle bezel off,
pry the panel away from the door working around the bottom first then the sides.
AND...
Those are the only two screws. Beyond that, however, there three more issues:
(1) you'll need to remove the plastic piece that encircles the interior door
handle; to do this, pull the handle forward like you're opening the door, and use
a flat blade screwdriver to pry inside the two small horizontal slots in the piece,
one above and one below the door handle. Be careful as it is easy to scar the plastic.
(2) there are 5 plastic force fit connectors that hold the panel to the door. These
are attached to the inside of the door panel, and they force fit into holes in the door.
3 of them are generally along the bottom of the panel, and the other 2 are just below
and above the front door speaker. I found it easier to start along the bottom. Use a
butter knife or a couple of small flat blade screwdrivers, and insert them along the
bottom of the door panel. You might start toward the rear of the door, at the location
where the door panel changes color if you have 2 tone interior, or where there are 2
panels if you have single color interior. You'll find one connector there. Put the
screwdrivers on both sides of the connector and pry, being careful because the vinyl
on the panel is paper thin. Once you've freed the first one then move along the bottom
edge of the panel & you'll find the next 2.
(3) the panel along its top edge has a lip that fits inside the top of the door
(i.e., where the window protrudes upward from the door). So, once you've gotten the
above removed, then lift the panel out and upward, pulling the lip upward and out of
the ridge in the door."
BTW: My brother's 2001 driver side door lock is doing the same thing.
JW....you got ANOTHER car????? what did ya get??? and I will get with a dealer on this one...
thanks Guys
R
A
T
time to go work :crazy:
[Modified by Ram Air Tony, 8:39 AM 10/31/2001]
I would rather just fix it myself if the part doesn't cost and arm and leg.
RAT, I got a 98 red coupe to commute back & forth to Dallas in. I'll be working a contract up there for the next year or so. :cheers:
JW.....schweet dawg ... now we can continue the Zaino Megs discussion over a COLD ONE !!!!! :cheers: :cheers:
I am gonna try to see what this part costs
thanks
R
A
T
10435192 *
Keyless Entry Fobs & Batteries
MODULE
1
$218.00 list
$163.50 wholesale
$130.80 our price
looks like I AINT buying it if that is the true stuff :(
thanks
R
A
T
MODULE
1
$218.00 list
$163.50 wholesale
$130.80 our price
So, since you've been so great with Zaino meet-ups in the past, and if you're interested, let me know if you have some weekend time & we could rip into RAT III.5's door panel! Otherwise, I think those directions above should get you there. :cheers:
JW...no Bro....that is the part that Bob found on the schematic.....it is in the CATEGORY of Key FObs......but it is a module........ and Bob called me back and confirmed the prices, so the part is the one :yesnod:
STEVE...... those were some GOOOD instructions !!!! I am gonna follow them and see if I cant fix it as you mentioned (a loose wire maybe) if not, to the dealer for hte $$$ part UNDER warranty :)
thanks
R
A
T
make sure they check the wiring going into the DCM if they're gonna replace it. From what you've described, if the relay inside the passenger DCM is clicking, the door lock motor should be moving. Things that would prevent that would be 1) bad solder joint on the printed circuit board inside the DCM (not likely but remotely possible), 2) expanded female terminal in the door harness connected to either the DCM or lock actuator (more likely), or 3) fault door actuator (don't know how likely this would be).
IOW, If the problem is #2, you could end up replacing the DCM - which may not be faulty in the first place - only to have it pop up again because the expanded female terminal (again) is not making contact.
Rotsa ruck.
A
Check the switch connection first. It's the easiest fix and could be the problem. If you don't check this connection it will appear anything you replace was the problem because you have to remove and replace the switch to remove and replace the door panel. The right side switch plate removes from the top and the driver side from the bottom. Place a non-marring wedge between the trim panel and the switch plate at the locations I just mentioned for the door you are working on and lift to remove. Now remove and reinstall the wire connector, that's it, now see if it works. If not, than at least you know you are not just switching out parts. These connections can come loose from slamming doors if they were not installed all the way from the factory or other repairs. When you reinstall, listen for the click.. I would think the plant can get loud and maybe not always able to hear this click.
thanks
R
A
T
