Part number for CV joint boot ?
Old Jul 6, 2007 | 03:16 AM
Juha's Avatar
Juha
Default Part number for CV joint boot ?
I'm looking for part number for outer CV joint boot, does anybody know it? I don't want to change whole shaft, just replace the boot.
Old Jul 7, 2007 | 01:21 AM
Juha's Avatar
Juha
Anybody? I have read that there is some kind of repairing kit available for CV joint boot?
Old Jul 7, 2007 | 08:53 AM
JEEP/C5's Avatar
JEEP/C5
I think JC Whitney has a generic replacement boot. It seems this topic came up in the past and no one had a corvette specific boot - you had to find generic replacement.
Can I ask why you want to replace it? Is it cracked badly? The reason I ask is if the boot is shot most likely you have driven your car that way for a while which means the grease has slung out and if you drive in the rain the grease would be contaminated. When a cv boot busts on front wheel drive cars I have owned it makes a big mess with grease slinging all over the place and the cv joint was improperly lubricated for perhaps a thousand miles or more before I noticed it (I check them at every oil change – 3000 miles). If I just replaced the boot then 6 months later the cv joint would probably gone out. It usually a good ideal to replace the whole axle shaft with a new one for piece of mind. Now if your car is not a daily driver and you caught the boot with minor damage then you may be ok with just the boot - but don’t forget to add some grease before the install.
If the crack is very minor you may be able to repair with come black RTV silicon. I have never tried it but I would think it would work.
Good luck.
Old Jul 7, 2007 | 10:23 AM
Juha's Avatar
Juha
Ok. My C5 is not a daily driver, it's only for a track use. And the boot has only a minor crack, and I noticed it after 50 miles (at most). I have tried to repair it with some gorilla tape (and of course I first added grease), but it doesn't last on a track so well. CV joint and the axle is fine, there's no need to replace them necessarily. I try to fix it next with RTV silicone, if it would last longer. Thanks for the tip.
By the way, I live in Finland so it might be impossible to get some products here from JC Whitney .
Old Jul 7, 2007 | 10:50 AM
Juha's Avatar
Juha
Yes, they have the replacement boot, I just checked. It only costs 10.99$, but unfortunately they don't ship overseas.
Old Jul 7, 2007 | 10:58 AM
chuckster's Avatar
chuckster
I rebuilt mine... if I had to do it over... I'd buy some axles off ebay...
http://forums.corvetteforum.com/show...highlight=axle
Old Jul 7, 2007 | 05:15 PM
thetaxman's Avatar
thetaxman
RTV will work if it's a small hole
To Part number for CV joint boot ?
