04 mass air question
Old Jul 6, 2007 | 05:29 PM
dr tint's Avatar
dr tint
1st Gear
Default 04 mass air question
on the 2004 is it possible to remove the stock honeycomb from infront of the maf sensor, if so do i have to worry about it causing any other problems?
Old Jul 6, 2007 | 05:53 PM
bcseitz's Avatar
bcseitz
You would be best off leaving it in.
On a stock or mildly modified LS1 you would not gain much of anything if you popped it out. The car might even run worse if not tuned for the change. I believe the maf tables are modified for the ZO6's which don't have the screen from the factory.
