mirror dislodged from visor
Old Jul 6, 2007 | 11:29 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Default mirror dislodged from visor
Help Please.
This concerns a 2001 coupe. Today the lighted mirror fell away from the sun-visor, and hung there from the electric wires. Shortly thereafter the other mirror dislodged from the other visor as well. Nothing appears to be broken on either one, but I’m not able to snap them back into place again, if that is even possible. Can someone help me with this dilemma.
Thank you for any input! Regards, GRT
Old Jul 7, 2007 | 12:27 AM
dougbfresh's Avatar
dougbfresh
The pins holding them in probably sheared. Nothing to do but replace them.
Old Jul 7, 2007 | 01:54 AM
rikhek's Avatar
rikhek
Happened to mine 2 weeks ago on passenger side. My pins are all sheared/broken. I'l figure a way to secure and look good, just haven't thought how yet.
Rick
Old Jul 7, 2007 | 04:23 AM
Blown 346's Avatar
Blown 346
I have the same problem, mine also broke. Im waiting for some to pop up on Ebay for the replacements.
Old Jul 7, 2007 | 05:39 AM
dougbfresh's Avatar
dougbfresh
I did use some construction adhesive to "gliue" is back the the felt till my new one came it. It did hold but looked a little "lumpy". It's a funky design.
Old Jul 7, 2007 | 12:38 PM
Nitro Junkie's Avatar
Nitro Junkie
I used clear RTV on mine. It worked fine, but about a year later, the entire visor broke, so I replaced it. Costs about $65.
Old Jul 7, 2007 | 02:50 PM
double-oh-coupe's Avatar
double-oh-coupe
I had the same problem, and this is how I fixed it.
http://forums.corvetteforum.com/show...=visor+zip+tie
I did all four corners ... took some staring, pondering, drinking a beer or two, but it worked. The 'top' is prerry easy -- the holes are already there for you. For the "bottom" of the mirror (when the visor is in the down position) I actually drilled through the hard material in the visor (be careful not to punch through the fabric on the other side) and used a zip tie to fix the bottom as well.
Good luck!
Old Jul 7, 2007 | 06:15 PM
C5 Pat's Avatar
C5 Pat
Default Mirrors
I can,t understand how GM can build such a beautiful car and put crap parts like these sunvisors. Both mine fell off, I got some wide black elastic at Wal Mart and made a band big enough to slide over the visor. You can't even see the band(black) but the mirror isn't functional. Ecklers have them for about $100
Old Jul 7, 2007 | 11:57 PM
Madddogg's Avatar
Madddogg
Mine are falling off too. Not off yet, but soon. Seems a little chincy, but I step on the gas and forget all about it.
Old Jul 8, 2007 | 11:45 AM
WFD088's Avatar
WFD088
3rd Gear
Default visor source ?
My passenger side visor appears to have broken in half internally. Can anyone give me a source for replacement visors. I've checked eBay, there is only junk parts currently. Found it on Ecklers for about $90. Any other sources ?
Thanks !
Old Jul 8, 2007 | 05:21 PM
ryoder's Avatar
ryoder
You can secure it with zip ties. I did and mine is holding very tight now.
Old Jul 13, 2007 | 10:31 PM
Nitro Junkie
Got mine at the dealer for $65. You might want to try here:
http://www.gmpartshouse.com/
Old Jul 13, 2007 | 11:28 PM
rpm462's Avatar
rpm462
...DeeGee did a great write-up on it...worked like a champ for me. See this thread:
Old Jul 14, 2007 | 05:58 AM
MDog00's Avatar
MDog00
Default Cheap Visors
My 04 was sideswiped by some illegal driving a Yellow Cab in November...the car didn't get completely repaired until March. While there the windshield and dash had to be removed. Of course the windshield broke coming out. When I finally get the car back the visor lid on the passenger side has one clip that either broke off or came unclipped. Can't get it back in place. So I take it back to get it fixed because the light stays on and drags the battery down . The jackass can't fix it, won't replace it and puts some velcro on the lid and mirror to hold the switch down So I guess I'll have to pay the 100.00 and buy a new one
To mirror dislodged from visor
