Need to know asap
Old Jul 7, 2007 | 03:05 PM
fearless's Avatar
fearless
Default Need to know asap
If I buy a set of wheels for my car that come with tire sensors already in them, do I have to have them programmed to my car, or will they work when I mount them on the car?? I am buying some from a forum member and don't know if I need to use my original sensors off of my wheels, Or if I can use his sensors. No need in breaking down two sets of tires if I don't have too
Old Jul 7, 2007 | 03:12 PM
dougbfresh's Avatar
dougbfresh
Need to retrain the car/sensors-no big deal.
Old Jul 7, 2007 | 03:39 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do a search and you'll find out how to re-program them. You will need a magnet.
Old Jul 7, 2007 | 03:55 PM
Bill Dearborn's Avatar
Bill Dearborn
The only issue is the year group of the cars the sensors are made to fit Vs the year of your car. Programming is easy if the years match as all you need is a cheap $1.00 magnet from Radio Shack to do the programming.
Bill
Old Jul 7, 2007 | 04:57 PM
fearless's Avatar
fearless
I think I will be keeping my own sensors and just put them in the new wheels.
Old Jul 7, 2007 | 06:09 PM
thetaxman's Avatar
thetaxman
if they are for the correct years of car, it doesn't matter
Old Jul 7, 2007 | 06:11 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I see from your profile you have a 2000 Vette. If the wheels you are buying are from a 2001 or newer Vette you will have to use your old sensors. Sensors from '97-'00 are not compatible with an '01-'04 car and visa versa. But if the new wheels are within the same years as your car it would be more advisable to reprogram them once installed on your car rather than risk damage during the sensor remove/install.
To Need to know asap
