I'm looking at some Weld EVO BC-10 wheels, the sizes are 18x9.5 fr. offset says +58mm, rears are 19x11 offset is +65mm, I dont want a wheel that is going to stick out any, will these fit and what size tires are you that have these sizes running...thanks jon c
The offsets are perfect, but I would use a 265/35/18 tire as the sidewall on the 275/35/18 tire is taller than the 305/30/19 tire.
Russ Kemp
So what if the sidewall is taller? It is irrelevant. Insofar as any concerns about AH, it's the diameter of the tires (or more precisely, the relationship between the front and rear tires' diameter) that is important. A 305/30-19 tire has a bigger diameter than a 275/35-18, and the 275 width is perfect for a 9.5" width wheel.
If that's the look your after, then use a taller sidewall tire on the front. It does look odd though. A 265/35/18 also is the perfect size for a 9.5 rim.
Russ Kemp
The difference in sidewall height between a 265/35 tire and a 275/35 tire is about .1". With 275/35 fronts, the sidewall will be about .2" taller than the sidewall of the 305/30; with a 265/35, the sidewall will be .1" taller than the sidewall of the rear. If you can see the .1" difference your eyes are better than mine. If you think that the latter combo looks odd, well, so be it.
