harmonic balancer replacement
Old Jul 15, 2007 | 11:08 PM
Sorny's Avatar
Sorny
Originally Posted by DidntSettle
Labor $633
Balancer and weights about $160
My Chev dealer did a very good job....not all dealers are equal though.
I had my pulley replaced (it wobbled a bit, and took out the front seal...) by DRM and the pulley portion of the work I had done was under $500 including parts (seal and balancer). The rest of the work I had done was some touch-up welding on my headers (developed a crack), fix the hanger on the driver's side muffler of my exhaust, and re-wire my driver's side O2 sensor since the harness fell down and melted. I also had the car dyno tuned (turned off CAGS, tweaked fan on temps, disabled the rear O2 checks, then the standard tune part).
All of that done by a well-known tuner shop for about a grand. Like you said, some shops are better than others.
Sorny
