P0443
Old Jul 12, 2007 | 08:54 PM
PaulWall's Avatar
PaulWall
Default P0443
I got a check engine light today and the code is P0443. What does that mean and whats the most likely problem. Its a 2000 coupewith only 30k miles on it. Thanks in advance
Old Jul 13, 2007 | 06:59 AM
trussme's Avatar
trussme
Default P0443
...in the DTC indicates a Purge Valve C FAULT in the EVAP Emission Control System.
Maybe another more-experienced Forum member will provide your best option to cure this situation....could be as easy as tightening or replacing a worn seal gas cap.
Old Jul 13, 2007 | 07:49 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Are you sure that's a P and not a B ?
The P codes start with 1
Attached link of codes
Old Jul 13, 2007 | 08:07 AM
BlackZ06's Avatar
BlackZ06
The list you link to is an abbreviated list.
Codes that start X0xxx (Where X=B,C,P,U and xxx=3 digits) are defined by the OBD2 standard and are common to ALL cars with OBD2. In other words, whether a GM vehicle, a Mercedes, or a Toyota, a P0443 is a Purge Valve fault in the EVAP system.
Codes that start with a digit otther than "zero" are defined by the manufacturer. So a P1555 might be a failure in a coil on a GM vehicle, and may be a failure of the Mass Air Flow Sensor on a Mercedes.
For a more complete list of Corvette DTC codes see:
http://www.davidfarmerstuff.com/
Old Jul 13, 2007 | 08:12 AM
phils C5 vette
http://www.corvettedoctor.com/2004_DTC_Codes_Page2.html
You are correct. Try this one
Old Jul 14, 2007 | 11:23 AM
PaulWall's Avatar
PaulWall
So according to the link above its a Evaporative Emission (EVAP) Purge Solenoid Control Circuit. Where is this located and is it just a quick fuse to repair or something?
Old Jul 14, 2007 | 11:39 AM
87SAM's Avatar
87SAM
Try this: http://www.gearchatter.com/viewtopic10203.php
To P0443
