OEM Tire Size
Old Jul 12, 2007 | 09:41 PM
DVLDAWG's Avatar
DVLDAWG
Default OEM Tire Size
What is the OEM tire 'width'. I knwo that its 17" fronts, and 18" rears, but what are the widths?
17x9.5 ???
18x10.5 ???
Thanks!
Old Jul 12, 2007 | 09:48 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The OEM wheel and tire sizes for C5 and Z06s are:
C5:
Front: 17x8.5" - 245/45/17
Rear: 18x9.5" - 275/40/18
Z06:
Front: 17x9.5" - 265/40/17
Rear: 18x10.5" - 295/35/18
Old Jul 12, 2007 | 09:52 PM
DVLDAWG's Avatar
DVLDAWG
C5:
Z06:
Thanks for the info - I hope I dont sound like too much of a moron, but I dont know much about tire and rim sizes. (I knwo what they mean, but not sure how to calculate what tire sizes will fit what rims)
I'm guessing tha the Z06 rim sizes will fit the coupe as a direct bolt-on? Also, will the smaller size tires (width) fit the Z06 rims? Basically could I put my stock tires on Z06 rims?
Thanks!
Old Jul 12, 2007 | 10:09 PM
wamara's Avatar
wamara
Cruise-In II Veteran
[QUOTE=DVLDAWG;1561051919]I knwo what they mean, but not sure how to calculate what tire sizes will fit what rims
There is no calculation per se, although after a time you will certainly get a sense of what size tire goes with what size wheel. Your best way of knowing is checking the tire manufacturer's specs - they will give you the range of wheel widths that will fit a given tire.
Z06 wheels will fit a coupe no problemo. You could put the coupe-size tires on a Z06-width wheel (as in it is possible), but I doubt you would find anyone who would say this is an ideal setup, or even recommended.
To OEM Tire Size
