6sp tranny fluid
Old Oct 31, 2001 | 02:34 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Default 6sp tranny fluid
anyone change theres? and did you do it yourself, I want to change to Synthetic,do i need any special tools? Thanks.
Old Oct 31, 2001 | 10:59 AM
BOBSZ06's Avatar
BOBSZ06
Default Re: 6sp tranny fluid (Rob 99)
I changed the factory stuff to Redline D4 ATF which is Dextron III ok. Works fine. Need 2 qts.
Check their site at http://www.redlineoil.com
:chevy
[Modified by BOBSZ06, 7:00 AM 10/31/2001]
Old Oct 31, 2001 | 11:36 AM
ajrls's Avatar
ajrls
only "special tool" you need is something to get the new fluid back into the trans. One inexpensive good "tool" is something you can get from pep boys. It looks like a huge syringe with a flexable hose instead of a needle. Ajter draining fluid and removing fill plug you just use the tool to suck the new fluid into it as you would a syringe and the put the flex hose into the trans and push the plunger again as you would a syringe to push the fluid into the trans. Repeat until fluid comes flowing out of trans fill. Jeff
Old Oct 31, 2001 | 12:55 PM
mprp's Avatar
mprp
Cruise-In II Veteran
Default Re: 6sp tranny fluid (ajrls)
Make sure you have the tranny level when you fill it. having it tilted for or aft will change the level at which it reaches the fill hole.
Old Oct 31, 2001 | 06:50 PM
vett1's Avatar
vett1
Default Re: 6sp tranny fluid (BOBSZ06)
:chevy
You only need 2 quarts? Where can you get Redline oil?
Thanks vette1 99 FRC TR 79 L-82
Old Oct 31, 2001 | 08:26 PM
jetskifast's Avatar
jetskifast
Default Re: 6sp tranny fluid (vett1)
You will need 4 qts. Expect to only get 3.5 to 3.75 qts in. Make sure transmission is level when you refill. Use cheap fluid pump you can buy at any auto parts store to fill transmission.
Shawn at http://www.thlapd.com sells Redline products.
Been using Redline products in my C5 for over 20,000 miles with great results:)
[Modified by jetskifast, 6:28 PM 10/31/2001]
Old Oct 31, 2001 | 08:30 PM
tslawsky's Avatar
tslawsky
Default Re: 6sp tranny fluid (mprp)
that picture doesn't look like Tampa :nono:
Old Oct 31, 2001 | 08:40 PM
davidfarmer's Avatar
davidfarmer
Default Re: 6sp tranny fluid (tslawsky)
I use Mobil 1, as it is easy to find at any Autozone.
To 6sp tranny fluid
