I cant find any links in search tool ?? I know the c6 zo6 calipers fit c5s do the rotors?. Will c6 z51 rotors and calipers fit a c5? Are the c6 calipers any better than the c5? Are the c6 z51 calipers the same as c6 standard calipers? Do you have to do anything with the brackets or hoses,ect. Do you have to go up to a 18 -19 wheel package also?
Thanks.
C6 Z06 calipers and rotors will fit a C5. you will need brake hoses and bigger wheels.
C6 and C5 calipers are the same.
C6 Z51 rotors are bigger than base C6 and C5 rotors. You will need C6 Z51 brackets if you use Z51 rotors and bigger wheels in the frt.
Slight difference in the piston size between base C6 and Z51 rear calipers. Not noticeable.
