Automatic transmission...died...some questions
Old Jul 17, 2007 | 05:30 PM
Erik88vette's Avatar
Erik88vette
Default Automatic transmission...died...some questions
Okay,this evening I had a litlle fun with my C5 with auto trans.Suddenly, with some kickdown action the rev limiter came on....what the hxxx is this. .It looks like my 4th gear is out...no where to be found.In 1st it takes about 4500 rpm before it wil shift,2nd seems okay.On the highway at 100 km/h it reads 2500 rpm and will not shift into 4th.
So I guess my gearbox is shot.How many of you guys have changed their auto transmission on the floor.Can it be done on jackstands??We have a litlle lift that levels the car at about 1,5 feet high.(45 cm)
Do I have to remove the tunnelplate?
Do I have to remove the torque tube?
Just need some info guys wether it can be done at home without any specific tools.
Thanks in advance, Greetz Erik(Holland)
Old Jul 17, 2007 | 07:19 PM
bobc997615's Avatar
bobc997615
Go to this link and look in the 3.42 rear swap
http://mikemercury.home.att.net/index.htm
Old Jul 18, 2007 | 07:34 AM
Erik88vette
I already found this topic from Mike after I posted this topic.Is it as easy as it is shown here??So the gearbox can eassily be removed from the torque tube with no hassle??Will the torque tube touch the tunnelplate after lowering the diff or is there enough space between TT and tunnelplate?I know,a lot of questions but for answers this is the best forum to seek them..
So in a few steps:
1 Remove the rear cradlle
2 Lower the diff and gearbox
3 Unbolt the gearbox + diff from torque tube?
Greetz Erik.
Old Jul 18, 2007 | 07:56 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It does sound like you lost your gears in the tranny.
You will have to get it rebuilt.
To take it out you should have no problem removing it and leaving in the tunnel plate. If it seems too tight then remove the tunnel plate and support the Torque tube.
You'll be suprised how easily the cradle and rear diff comes out along with the transmission.
Use a tranny jack to support the diff and trans, you will not have to be too high in the back with the Vette either.
Hope all goes well.
See the For Sale section VADER 87 Has a good used tranny for sale.
http://forums.corvetteforum.com/show...For+Sale+4L60E
Thanks,Matt
Old Jul 18, 2007 | 08:13 AM
Erik88vette
Okay,so the transmission can simply be unbolted from the torque tube as in the conventional engine to transmission setup's.Just unbolt the torque converter and then the transmission and slide it out of the torque tube???
Greetz Erik
Old Jul 18, 2007 | 08:18 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I just recently pulled my auto trans out to install a 6 speed tranny.
You wnat to get the most clearance that you can when jacking up the car.
Once you have the car in the air.
Follow one of the removal guides out there for manual tranny.
-There are some differences. You need to drain tranny and rear end fluids.
-Disconnect tranny cooling lines and shifter cable. Also remove all electrical connectors from tranny.
-Unbolt and slide off of torques tube. Make sure use a tranny jack, it will make job easier.
Old Jul 18, 2007 | 08:26 AM
Erik88vette
Okay,but the torque converter is at the back against the tranny??How is it bolted on....on what....the flexplate is at the front??
Maybe some pics will clear things.
PS ,thanks for the replys sofar...I really appreciate it!!
Greetz Erik.
Old Jul 18, 2007 | 08:37 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Greetz Erik.
Check out this thread, I think it will answer most of your questions.
http://forums.corvetteforum.com/show....php?t=1753571
Old Jul 18, 2007 | 11:43 AM
Erik88vette
WOW....very nice info....
Greetz Erik.
Old Jul 18, 2007 | 05:43 PM
felga's Avatar
felga
You swaped A4 with 6sp manual ?
Do You have any info about that ?
Someone aid that it`s easier and cheaper to buy another vette with manual transmission than swap them.
ANdy
Old Jul 18, 2007 | 08:22 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
ANdy
Andy,
It's not a job for the novice. I had a lot of support from Dr Phil, DTE, ECS and RPM.
The process requires gathering all of the parts and then some re-wiring.
The amount of re-wiring is dependent on wheher or not you swap out the tranny wiring harness or use the existing one. I choose to swap out the existing one.
Cost are dependent on a number of variables. I knew one day that I would want to make a lot of horsepower so I went all out.
- Clutch and Brake Pedal Assembly from a stick shift car.
- Manual wiring Harness from a car that was produced close to when mine was.
- Textralia Twin Clutch
- 2003 Z06 Torque tube and bell housing. Rubber front & aluminum rear bushings.
- RPM stage V tranny (base unit was a MN6).
- DTE Stage V Rear Differential and Brace.
- Other miscellaneous parts (fluid, tranny mounts, wire, switches, etc.)
Total parts cost was north of $10K. I will probably recover about $2K from the sale of the automatic drive train and associated parts.
If you don't crazy like me you could probably do the job for around $2 to $3 thousand, net. (Sale of auto parts).
If I had it to do over again, I probably would have hauled the car off to RPM to do the job, but at the time it just wasn't feasible due to all of the other in process projects.
If you need any additional info just drop me a PM.
Tony
Old Jul 18, 2007 | 09:20 PM
bobc997615's Avatar
bobc997615
If you have to drop the tunnel plate, the H-pipe has to come off to gain access to all the bolts on the tunnel plate
To Automatic transmission...died...some questions
