H/C and LG Pros Install Question
Old Jul 17, 2007 | 06:31 PM
CodeName Z06's Avatar
CodeName Z06
Default H/C and LG Pros Install Question
I am going to install a TSP Torquer v.2 cam 232/234 .595/.598 and probably porting the stock heads due to lack of funds. I am also going to intall some LG Pros while i am at it. My question is what do i need to do the install besides the cam and headers. What gasket should i use for the headers?
LS2 time chain, o-ring or gaskets?
Should i use a thinner gasket to increase compustion pressure, and are the valves going to hit if i use a thinner gasket?
Sorry for the all the questions just need to make sure i order everthing i need. Thanks in advanced
Old Jul 17, 2007 | 09:02 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
With the LG Pros use an F body gasket, GM P/N 12558573. The holes are round instead of D-shaped like the Vette ones.
Old Jul 18, 2007 | 12:16 AM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
LS1HOWTO should point you in the right direction on what you might need, i used this when i did my H/C in my garage, also upgraded to a LS2 timing chane and ASP underdrive pully...and go with what Jason said with the F body gaskets for the headers.
Old Jul 18, 2007 | 12:45 AM
CodeName Z06
Sounds good i will have a look, what head gasket should i use?
Should i use a thinner one to increase compression?
Old Jul 18, 2007 | 12:45 PM
CodeName Z06
TTT Any imput would be great.
Old Jul 18, 2007 | 03:32 PM
torchredfrc's Avatar
torchredfrc
I would recommend the stock MLS head gasket. I've heard good and bad stories about the cometics gaskets (no 1st hand experience with them though).
If you're certain you won't mess up your valve train geometry the thinner gasket may give you a little more compression but I would think the gains would be nominal unless you mill the heads.
Old Jul 18, 2007 | 04:05 PM
CodeName Z06
So if i stick to the stock does the GM offer a packet with all the gaskets or o-rings, does anyone have a part # for it?
Old Jul 18, 2007 | 11:46 PM
torchredfrc
I believe the MLS head gasket part number is 12498544 but give Gene at GMPartsHouse.com a call to verify.
As far as a packet is concerned, there is not one that I know of but you can get a list of parts you need for a H/C swap at ls1howto.com.
I just recently did a heads swap on my car, I've got picturs of it:
http://www.thend.org/~mkane/Corvette/gallery
if you're interested.
Old Jul 19, 2007 | 12:21 PM
CodeName Z06
Thanks for the pics, i am sure they are going to come in handy once i start tearing apart the engine.
To H/C and LG Pros Install Question
