Hard to shift - what can cause?
Still was doing it so I took it back in for service and told the tech to "drive the car hard" to duplicate it! ... My problem is when you would drive hard and come to a stop you couldn't get the car back in first.
Long story short: Shift Linkage adjustment and now all is fine.
1] Apply the parking brake.
2] Remove the shift control closeout boot. Refer to Shift Control Shift Closeout Boot Replacement .
3] Place the shifter into NEUTRAL.
4] Press down to engage the shift control neutral lock pin.
5] Loosen the transmission shift rod clamp bolt.
6] Loosen the shift control mounting bolts.
7] Check that the shift control locator (on the underside of the shift control) is installed into the shifter bracket on the side of the driveline support assembly.
8] Tighten the shift control mounting bolts. Tighten the shift control mounting bolts to 30 N·m (22 lb ft).
9] Tighten the transmission shift rod clamp bolt.
Tighten the transmission shift rod clamp bolt to 30 N·m (22 lb ft).
10] Lift to release the shift control neutral lock pin.
11] Install the shift control closeout boot. Refer to Shift Control Shift Closeout Boot Replacement .
12] Release the parking brake.
It's at the shop now, but they're talking about replacing it because transmissions are 'too hard' to work on. It's only got 6500 miles + one good jarring hit from an idiot; is there some other stuff I can ask the shop to try first before pulling the whole thing?
http://forums.corvetteforum.com/zerothread?id=132290 is the only thread I found that sounds similar. c4c5specialist mentioned 'you should perform a shifter adjustment first', so I'll mention that, but more suggestions and more detail would be welcome (I'm also afraid if I say 'please perform a shifter adjustment' they'll look at me like I'm an idiot or not have a clue what I mean; I am an idiot on these cars so far, but would like to fix that to some extent).
Thanks,
David
