Radio lamp
Old Jul 17, 2007 | 07:54 PM
robertp's Avatar
robertp
Default Radio lamp
The lamp that illuminates the middle two tuning buttons on my Bose radio is out. Has anybody ever changed these lamps? Is it a difficult fix?
Old Jul 18, 2007 | 12:24 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes, I've had to change the lamps in mine. Like any lamp, they won't last forever. With the right lamps, a soldering iron and knowledge of how to use one, you can indeed change the lamps. I suggest that you change them all at the same time as you will be having others burn out soon enough anyway. The proper lamp is a 70ma@12vdc. Some people said they found some 65ma or 60ma at RadioShack.
The one I used was this one:
http://www.partsexpress.com/pe/pshow...TOKEN=76124724
It takes a little more to remove the insulation and unsolder the leads, but it will work perfectly for brightness. I will also suggest that you replace the ones in the HVAC controller as well at the same time.
Old Jul 18, 2007 | 07:50 AM
robertp's Avatar
robertp
Thanks. I ain't sceeerd. I'll give it a shot.
To Radio lamp
