I am planning on changing out the stock 195 degree thermostat and I'm looking for some advice on which new stat to install. I want to try changing my thermostat only at this time to reduce the operating temperature (no fan switch) and would like to hear from anyone who has tried this mod. Thanks!
:cool:
You must either install a fan switch or have pcm. reprogramed to turn your fans on earlier. Just installing a 160 or 180 t.stat. will not lower your cars operating tempts. much especially if you get stuck in traffic. If you live were it gets cold and you have to use your heater go with the 180 t.stat. If you live in a place where it is hot a good part of the year go with the 160.
IMO go with the 160. That is supposedly the temp it STARTS to open. It's not fully open until the temp is somewhat higher. With the 160 mine runs 175 to 185 in stop and go city traffic. With airflow over the radiator, either by driving at speeds over 45 mph, or by turning the fans on, it stays at 170 to 175. Unless they have changed the 178 thermostats in the last year, DON'T WASTE YOUR MONEY ON THEM. THEY DON'T WORK. I bought two of the pieces of junk, sent them back. They open as they should, but don't close to regulate the coolant temp. You end up running the engine WAY TOO COLD if the air temp gets below 50 degrees. :U Spend a buck more and get a new Hypertech 160, not the 178 which is a badly modified factory unit. If it gets cold where you live, you'll thank me. :yesnod:
If you plan on keeping the car a while, I would stick with stock. The HP claims of going to an aftermarket "modified stock" unit are dubious. Many on these "aftemarket" units are poor quality hack jobs of the OEM unit. Depending on where you are located, in the cold months, you can do subtle damage to your engine driving it hard until the engine gets up to temperature. You need to get the oil and combustion chamber up to temp ASAP. Putting in a 160 deg unit only makes it worse. I live in FL. During cold days in winter, it takes my engine way too long to get up to temp. It rarely gets below 45 deg, nevermind freezing in winter.
Marine engines run a 145 deg thermostat because the salt in salt water precipitates out and clogs the engine cooline passages if run at say 180-200 deg. The engines suffer from long term problems due to running at these cooler temps. You never really get the oil hot enough to cook off moisture in it unless you push the engines hard.
99HT brings up a good question. Has anyone noticed the effect on oil temp before and after installing a colder t-stat? How hot does your oil get when fully warmed up? (my oil temp is around 200 - 205 in normal driving, coolant temp 195 in normal driving on open road). For wear and tear on the engine, and frequency of oil changes, getting oil fully warmed up is very important. I don't run my cars hard until the oil is warmed up enough to flow properly. I would welcome any input on this. You should note that the oil temp comes up much slower than coolant temp.
