gauge cluster help
Old Jul 19, 2007 | 01:42 PM
grunz95's Avatar
grunz95
Default gauge cluster help
Does anyone know of a thread on how to remove the gauge cluster? I just purchased a set of alum. bezels.
Thanks In Advance.
Gary
Old Jul 19, 2007 | 03:21 PM
rwlc5's Avatar
rwlc5
Go to www.vetteessentials.com they have detailed instructions. If you have access to a color printer, print them out so you can have them at hand as you do the install. I used them and everything went fine. Just take your time.
Old Jul 19, 2007 | 04:03 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep, best set of instructions going.........
Old Jul 19, 2007 | 09:06 PM
grunz95's Avatar
grunz95
Thank you for the thread. I printed the information. I really don't know if I want to tackle it.
Gary
Old Jul 20, 2007 | 08:16 AM
mrm1149's Avatar
mrm1149
It looks more intimidating than it is Gary. Just set aside a 3 hour or so block of time and don't rush.........Clean the trim rings and the black rings around the gauges with denatured alcohol (use q tips) and use numerous tiny dots of the superglue gel around the rings. Just time consuming but well worth the results.
Old Jul 23, 2007 | 08:09 PM
grunz95's Avatar
grunz95
Mike, I have a question, I had hear that you can not lay the cluster down face first is that true?
Gary
Old Jul 23, 2007 | 08:29 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Gary
there is a note in the service manual concerning this, i forget if it's face down or up
Old Jul 24, 2007 | 07:04 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Gary
Yeah, have heard this. I had my lying face up for an hour or so while i did the bezels/they dried. I figure when GM ships out a new cluster it ends up being face up/down during delivery so, well, I dunno. Don't think I've ever heard of one going bad though. I guess in the end, I dunno.
Helpful, eh?
Old Jul 24, 2007 | 07:20 AM
mrm1149's Avatar
mrm1149
When I did mine I kept it upright except when gluing on the rings, to do that it had to lay face up of course. No problems at all nearly a year later
Old Jul 28, 2007 | 04:00 PM
grunz95's Avatar
grunz95
Default Thanks
I want to thank all of you for the threads. The instructions from vetteessentials was great. If took me about 3 1/2 hours. I cleaned all the parts before replacing them.
ThanksAgain,
Gary
To gauge cluster help
