POST LG Pro LT install Questions
I recently finished up installing a set of LG Pro LT's with off road pipes - full exhaust - x-pipe and everything.
I have a '03 Z06.
After the first start, I went for a test run.
The first half hour the car drove well - I wasn't pushing it - just wanted to drive around and get all of the smoke out from the new pipes.
The second half hour of driving it - the car started backfiring at low RPM. Either while its idling or when I am at a stop sign and about to start out in 1st gear. When I am above 1000 or so RPM it does NOT backfire.
The car's motor also jerks a little at speed when in gear and I am applying gas. It stops this when I let off the accelerator.
I have the rear O2 sensors plugged into the front sockets w\the LG supplied adapters. I have O2 sims where the rear O2 sims once plugged into the wiring harness.
I have the right side O2 sensor going to the right side header and I have the left side O2 sensor going to the left header....which i confirmed today is correct with LG.
What am i doing wrong? Why is my car backfiring at low RPM. Why does the motor jerk\hesitate when accelerating?
WTF? is going on???? THANKS GUYS!!!
ALSO - I have ZERO Codes on the DIC.
I've had 3 people tell me just the opposite - Headers = Rich condition...
I'm not an expert either....thankfully there are forums like this...
I don't think there is anything wrong there. The motor runs smooth. Plus if I did mess something up when reinstalling wouldn't I have a code about it??
Just thought this was worth mentioning because - I had someone tell me that could be the problem when I describe the motor hesitation\backfiring....
thanks. HELP????
I had a similar problem.
Are you ABSOLUTELY SURE that you got the O2 sensor wiring right? When I did my headers I thought I had it right, and then when I took them off, I noticed that I had wired incorrectly.
O.K. Just crawled out from underneath a rock - I mean my car....
I have now double checked my wires. Everything is going left to left and right to right.
The 2 O2 sims are in the square connector in the wire harness and the cables for the O2 sensors (which are square - I used the LG square to flat round adapter) are plugged into the flat connectors on the wiring harness.
I think I am good with the O2 wiring and sims. I will now lower the car and double check plug wires. I did remove plugs and wires before removing stock manifolds.
anybody have any other thoughts...
HELP!!!
When I push the plug boot onto the spark plugs - should I feel anything. All I did was push on the boot and then try tugging back - if it didn't pull out - I assumed everything is good.
Thanks.
thanks.
I did check the wires themselves right now also. I used a shielding material when i did the whole header install. My starter got wrapped and various cables with this stuff. Anything near the headers was wrapped with this stuff.... i really tried doing a nice clean install to minimize issues.....
This stuff is great. It is very pliable and has a very sticky back. I used it to wrap the O2 sensors and sims. I used it on the starter housing. I used it on the starter wires. Where ever it looked like some thing was to close to the header tubes - I applied this stuff. ***IMPORTANT*** I also wrapped the clutch line on the drivers side. If this catches on fire - your car is toast. Just some advice that was given to me from a friend.
When you put them back on the coil wire should snap (click) twice. the spark plug end once, but it's very hard to feel.
I have been out driving my machine....
Let me walk you through what i discovered this morning....
So - I'm under the car again double checking that I have the O2 wires correctly positioned.
I'm thinking what the F^&K could be my next move....
I slide up to the front of the car on my creeper - and look up on the driver side. I can clearly see all the plug boots for the spark plugs. I notice the one on the driver side nearest to the fire wall...
I see the tip of the spark plug and the spring around it from the plug boot.SOOOOOOO - I'm like thats not right.
I lower the car and remove the AIR tube and tug on it a little - it came right off...
SO I push on it real good and put everything back together - start it up - ZERO LOW RPM BACKFIRE - Drive it around for the next 40 minutes and it RUNS LIKE A CHAMP!!!!
I am so happy at this point:
1. I did the install myself
2. I put it all back together without any problems
3. I trouble shooted it myself and fixed it
The car sound mean!!!!
Now I'm charging up the camera to make a vid...
THANKS ALL!!!
Is there anything I can buy thats better out there? I was thinking of doing new wires and boots - maybe something that's better than the factory plug boots????
Or should I just shut up and go drive my beast....
But you are correct. Had I rechecked my plug connections 2 days ago - I would have found the prob then.....
Thanks!!
