Leaf Springs
Old Jul 21, 2007 | 05:00 PM
Camaroguy22's Avatar
Camaroguy22
Default Leaf Springs
I know that all base suspension springs are the same for C5 years.
Does anyone have the spring rates for all the different springs/years.
Ex the rates for 97-99 Z51 springs vs. 00+ Z51 springs etc.
Old Jul 22, 2007 | 08:39 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
The Z51 front is 502lbs/in
the rear is 645lbs/in
the Z06 front is 526lbs/in
the rear is 714lbs/in
Stock Z06: 526# Front, 714# Rear
T1: 582# Front, 793# Rear
sources-
http://forums.corvetteforum.com/show...23&postcount=3
http://forums.corvetteforum.com/show...0&postcount=21
http://forums.corvetteforum.com/show...k+spring+rates
Hope this helps some.
Old Jul 22, 2007 | 12:24 PM
Camaroguy22
Thank you. I should have clarified what I was after. I have read on here there are differences between A4 and M6 Z51 springs and also differences between 97-99 and 00+ yet I cannot find any actual spring rate numbers to tell that difference.
Old Jul 22, 2007 | 05:32 PM
bcseitz's Avatar
bcseitz
The "Sticky's" are a great place to find info. !
Yes, the base and Z51 cars w/A4's have a slightly beefier rear spring.
From the "Weights, Measurements, ect, ect," "sticky" on C5 General:
Spring Rates
439.66 lb/in, front; 576.70 lb/in, rear (manual trans); 588.12 lb/in, rear (auto trans) --- FE-1/Base --- Source
440 lb/in, front; 577 lb/in, rear --- FE-1/Base --- Source
457 lb/in, front; 577 lb/in, rear --- MSRC --- Source
525 lb/in, front --- FE-3/Z51 --- Source
660 lb/in, front --- FE-3/Z51 --- Source
327 lb/in, rear --- FE-3/Z51 --- Source
633 lb/in, rear --- FE-3/Z51 --- Source
634 lb/in, rear --- FE-3/Z51 --- Source
525.31 lb/in, front; 633.80 lb/in, rear (manual trans); 645.22 lb/in, rear (auto trans) --- FE-3/Z51 --- Source
525 lb/in, front; 634 lb/in, rear --- FE-3/Z51 --- Source
620 lb/in, rear --- FE-4/Z06 --- Source
650 lb/in, front; 680 lb/in, rear --- FE-4/Z06 --- Source
525 lb/in, front; 714 lb/in, rear --- FE-4/Z06 --- Source
650 lb/in, front; 800 lb/in, rear --- T1 --- Source
1,000 lb/in, front; 680 lb/in, rear --- Danny Popp's setup --- Source
77 N/mm --- FE1 & F45 front suspension spring rate --- SAE SP-1282
1.15 Hz --- FE1 & F45 front suspension ride frequency --- SAE SP-1282
103 N/mm --- FE1 & F45 rear suspension spring rate --- SAE SP-1282
1.36 Hz --- FE1 & F45 rear suspension ride frequency --- SAE SP-1282
1.18 --- FE1 & F45 Ride frequency ratio --- SAE SP-1282
93 N/mm --- FE3 front suspension spring rate --- SAE SP-1282
1.20 Hz --- FE3 front suspension ride frequency --- SAE SP-1282
113 N/mm --- FE3 rear suspension spring rate --- SAE SP-1282
1.45 Hz --- FE3 rear suspension ride frequency --- SAE SP-1282
1.21 --- FE3 Ride frequency ratio --- SAE SP-1282
Old Jul 23, 2007 | 01:02 AM
Camaroguy22
Spring Rates
[U]525 lb/in, front --- FE-3/Z51 --- Source
Yes I have read that sticky before, thank you. The sticky has jumbled numbers that do not make sense. It also does not have any distinction between years. As one member stated that 99 and older have different rates I still have seen no numbers pointing that out.
Old Jul 23, 2007 | 07:36 AM
TorchRed00FRC's Avatar
TorchRed00FRC
Here is the info I have found on spring rates.
Springs
Base...440/577
FE3 -Z51....525/634
FE4- Z06....525/714
I think what changed in 2000 FE3-Z51 suspension was the sway bar sizes were increased. • Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06). I do not find anything suggesting that the spring rates changed.
Going by the part number molded in the the spring, I know at least the 2000 FE3-Z51 option had the same front spring as later years Z06. I purchased a set of Z06 springs to swap out the Z51 and only did the rear spring since the front was the same. Then sold the Z51 set for what I paid for the Z06 set. No cost modding!
Old Jul 24, 2007 | 04:59 PM
Camaroguy22
So is this Z51 front spring part number # 22171750 the same as the Z06 front?? (looked but could not find anything)
Old Jul 24, 2007 | 06:22 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Z06 Front spring: 22178729(same as 00+Z51)
To Leaf Springs
