Door Lock
Old Jul 21, 2007 | 05:30 PM
emj's Avatar
emj
Default Door Lock
On the R door, using the remote lock, sometimes the door locks and sometimes it doesn't. The L door seems fine. It sounds like there is a clicking noise whether the lock closes or not. I've been reading several of the releated posts and decided to first of all check the electrical grounds. I know this is probably not the problem, but there have been several electrical codes: B1527, B2282, B2286, B2284, U1016,U1096, B2283, B2285, U1064, and U1016.
Next is the door. I was ready to replace the relays using the 2 excellent tutorials on this site, until I read one post where this did not fix the problem. A door lock solenoid was suspect. Is there any way to determine which is the problem from the get go?
Steve
Old Jul 21, 2007 | 05:58 PM
Rabo Karabekian's Avatar
Rabo Karabekian
Steve
You'll have to get the circuit board out of the module and reconnect it; then see if voltage is present on the coil terminals of the relay when lock is activated. My 98 had same problem; relay was at fault. Replaced both lock and unlock on driver's door; no more problems. Cheap fix using the Digi-Key parts... RK.
Old Jul 21, 2007 | 06:25 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
HUMMMMM......My '01 sometimes has the same issue...and best place to buy "Digi-Key" parts????
Old Jul 21, 2007 | 07:17 PM
rws.1's Avatar
rws.1
ummm direct from Digi-Key
http://www.digikey.com/
Old Jul 21, 2007 | 07:40 PM
emj's Avatar
emj
Default door lock
Thanks for the info....emj
Old Jul 21, 2007 | 08:14 PM
hisvett's Avatar
hisvett
Maybe a part number for us dummies?????
To Door Lock
