Head and Intake Swap
I own a set of LS6 (243 Casting) Cylinder Heads and a LS6 Intake Manifold that I Plan on swapping onto my LS1 '97 MN6 Coupe.
Before I can get started I need a few things.
A) Britco Racing Engines to Port my LS6 Heads - $400
B) OEM Cylinder Head Gaskets $48.99
C) LS1 to LS6 Intake Conversion Kit $44.99
D) Center Bolt Valve Covers to Replace my Perimeter Bolt LS1 style valve covers $?? (Anyone selling these?
)E) OEM Cylinder Head Bolt Kit $47.99
I'm going to start gathering up everything I need for this. I was looking for a write up detailing just a Head/Intake swap and not a Head/Cam swap - because w/ a cam Swap there are a lot of other things that get R&R'd which aren't needed to do the heads...
If someone has a good writeup on a Head Swap only that'd be really useful...
Also when i pull the heads and intake - what other things am I going to need? Other gaskets or anything?
-Dan
1. Drain the coolant.
2. Remove the intake, injectors and other related hardware.
3. Remove the belt, alternator and alternator bracket (royal pain)
4. Remove the coils and their brackets.
5. Remove the temp sensor from the DR head.
6. Remove the plugs and plug wires
7. Remove the valvecovers
8. Remove the rocker arms and pushrods
9. Remove the manifolds/headers
10. Remove the heads.
11. Remove coolant plug on old PS head - move to new head
Clean the block and reinstall. You'll need head gaskets, exhaust gaskets, anti seize and some RTV. As far as your head porting choice, unless the shop mentioned has a lot of experience with LSx heads you would be much better off sending these to a sponsor shop (like TEA) to get your work done. Flow numbers aren't the end all to a good head. There's much more to it.
Have your LS6 intake ported to the heads you installing.
Good luck
Good luck
At this point I just want to toss on the heads & Intake real quick - just cause i can do that pretty easily in my own garage... i'm trying to keep the cost down - i don't need the best of the best, just OEM quality is fine w/ me...
It was my understanding that porting the LS6 intake was kind of pointless? Am i wrong? Is there an actual gain with a Ported LS6 intake manifold?
-Dan
From what I can tell, there are bracket bolts that are behind the power steering pump pulley, so the pulley has to come off to get the bolts out, which means you have to have room to pull the pulley, which means the brake modulation dingus has to come off, which means the radiator needs to come out. Not seeing an end here. Say it ain't so.
Remove the 4 bolts holding the alternator bracket to the head, and push it forward, away from the head.
It is easier to remove the water pump to get to the bottom 2 alt bracket bolts. But you don't need to touch the pulley, the pump, or any steering components to do this job.
-Dan
http://forums.corvetteforum.com/show...intake+porting
If you plan to R&R the heads, I would really think about the ARP head bolts, because these are easier to torque and can be reused. There is the ARP bolt kit that comes with not only bolts but with studs to make R&R heads faster. The OEM bolts are "stretch bolts" and can be only used ONCE.
My $.02
http://www.ls1howto.com/index.php?article=1
There is a host of other things to see on this site as well! So check'em out
Thanks,Matt
My $.02
But in Roberts thread he mentioned the HP gain between the porting of a LS6 and a LS2 intake and the LS6 gained more HP...
I have the stock lifters still and about 78k Miles on the engine... is it worth it to throw in some new lifters? Again this is a budget build, so OEM quality is fine w/ me... i think GM LS7 style lifters are $135 from Texas-Speed....
-Dan
The LS7 lifters (p/n 12499225) are $99/set from SDPC, and the guides (p/n 12551162) are $4 ea (you'll need 4) also availabe from SDPC too.
http://www.sdparts.com/catalog/lsgen...IILifters.aspx
